Don’t forget air to water is not the only game in town. Air to air is also a very viable option, is used extensively in the states and is actually more efficient than air to water. Tepio heat stores offer viable high temperature solutions using cheap off peak electricity.
Hot water can be achieved using other means but in reality, most low energy/low running cost hot water solutions need a cylinder of some kind somewhere. I’ve seen people out these in unheated outhouses, garages etc so they don’t necessarily need to be in the house itself.
Air to air isn’t necessarily a central forced air system. Using normal ‘air conditioning’ multi splits is more typical for a retrofit.Bit of a pita to install a forced air system though!
Whoever started the myth that removing cylinders was an upgrade needs to be shotThe fact they need a HW cylinder makes a HP a pretty unreasonable change. Gas combi for me for the time being.
Upstairs can be handled by a single or multiple loft mount units and the rest use normal wall units in each room.
The bonus is they cool as well as heat, modern ones can also heat water cylinders also if you want.
It would be a lot easier for us than to re-plumb the house.Bit of a pita to install a forced air system though!
Combi on demand hot water is way more efficient if your hot water use is low to moderate. Plus without any Legionnaires' to worry about you can have the hot water as low as you like. Mines set to 42c.Whoever started the myth that removing cylinders was an upgrade needs to be shot(not pointed at you, I just know a lot of folk who thought that way).
It was for us.Whoever started the myth that removing cylinders was an upgrade needs to be shot(not pointed at you, I just know a lot of folk who thought that way).
Yeah if you have dead legs, it can be a problem, but you shouldn't really have those in most properties.If you have a modern system the losses from a tank of water is so low its hardly going to be noticeable.
Its technically incorrect in regards Legionnaires as well.
If you do not fully flush ALL the hot water pipes regularly then it can still be in the system.
Its much lower risk, but its not eliminated by simply having a combi, especially if your a very low user so probably not getting the whole system properly hot regularly.
You want water to be proper hot or proper cold to kill it. Tepid water is the problem.
Show me your gas bill and I'll show you mineCombi on demand hot water is way more efficient if your hot water use is low to moderate. Plus without any Legionnaires' to worry about you can have the hot water as low as you like. Mines set to 42c.
Bit pointless since it's impossible to know how much hot water we've used.Show me your gas bill and I'll show you mine
I didn't want to play this game anywayDone
(Last full month is July as the meter reader came round in Sept and took gas half way through Sept and house was empty for 2 weeks in August)
