Pics?
I'd just use touch up paint if you're not too concerned about the appearance.
How can I post one? I'm on a phone
The cars black so it will look oddJust leave it it’ll go a bit brown that’s all.
Yeah but if you paint it it won’t match and then as you keep trying it will get bigger. As long as it doesn’t get worse which it won’t leave it ( is my advice, I have many years experience of trying to make things look ok)Posted a pic just needs to be approved by a mod.
No, the seat belt you pull over you.Was it from a Gucci belt?
Curious now.It's an old car. Potential classic one day.
just invented the gucci seat beltWas it from a Gucci belt?
Door shut says Ford… probs a MondeoCurious now.
ST220. Sheesh I'm bored!Door shut says Ford… probs a Mondeo
I think upgrading to a HGV just to avoid this issue in future is a bit extreme![]()
I've done this more times than I care to remember, I can only assume a truck has by far thicker paintwork!
My current steed has a mere 558k miles (it's increased since the photo) under its wheels, its paintwork is just fine![]()
Corner seat?just invented the gucci seat belt
