New PC spec for advice
7 Oct 2023
England
Hi,
I'd appreciate help on a possible spec for a new pc. I'm replacing an 8 yr old pc that is too old to upgrade to Win11. The spec doesn't seem bad by numbers (AMD FX(tm)-6300 Six-Core Processor 3.50 GHz, 16 GB RAM) but is obviously old and worn out and doesn't have dedicated a GPU. Wifi keeps crashing as I only have a dongle, so that needs to be integrated.
I use it for photo processing on Lightroom and Photoshop, gaming and household admin. I don't play fast games but those with quality graphics like Myst, Talos Principle and Quern. I want to get into VR. I've looked at the recommended specs for the games I play and CPU is split Intel i5 / i7 / AMD Ryzen 5 / 7. Recommended graphics are mainly RTX 1070 or 2080. I want to future proof as much as possible while I have the cash as there are a few new games due in the next 12 months with no spec released yet. Therefore I would look at the top whack of what's recommended now plus a bit (Ryzen 9 x3d, RTX 40 series). 32 GB RAM is recommended and 12GB VRAM. After reading a few articles I'm looking at AMD again as I believe Intel are changing something soon that AMD aren't. ;)
My budget is £2k-ish as I also need a new monitor. I've only had AMD before (Intel has seemed like paying too much for the name) but I'm willing to switch if appropriate given what I've put above.
As I started looking I said I don't need the pretty, but the more I look the more I want it! I really like the Kolink Void Rift ARGB Midi Tower Gaming Case but I'm struggling to configure that with the right spec on this site. So what I've ended up with so far is:
OcUK Gaming Buzzard - AMD Ryzen 5 7600 Radeon RX 7600 Gaming PC
SKU FS-19D-OG
  • 1x Kolink Void Rift ARGB Midi Tower Gaming Case - Black
  • 1x AMD Ryzen 7 7700 Eight Core 5.30GHz (Socket AM5) Processor - Retail
  • 1x Kingston FURY Beast EXPO RGB 32GB (2x16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit (KF556C36BBEAK2-32)
  • 1x Sapphire Radeon RX 6750 XT Pulse Gaming OC 12GB GDDR6 PCI-Express Graphics Card
  • 1x WD Black SN770 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T3X0E)
  • 1x Samsung 1TB 870 QVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-77Q1T0BW)
  • 1x Build Stock Microsoft Windows 11 Home Advanced - Systems
Quantity: 1
£1,489.49 - this seems cheap compared to other retailers so I'm not sure if I've missed anything. Specifically, I don't see an option to select a motherboard.
Thanks
My understanding is that nvidia is better for VR, but you may want to ask in the VR forum.
What resolution were you planning on for the monitor?
An example £2K self-build:
My basket at OcUK:
Total: £2,000.84 (includes delivery: £0.00)​
As per usual, @Tetras had put together a great spec. I concur that my understanding is Nvidia is better for VR but that being said, my kids haven't had a problem with Meta Quest 2 and a 6700 10GB.
Glad to see he specced 1x2TB SDD instead of 2x1TB. The only thing I would change is the RAM to the Kingston Renegade Fury 6000MHz C32 for an extra £30.
My basket at OcUK:
Total: £1,973.86 (includes delivery: £0.00)​
cpu cooler = thermalright peerless assassin​
this is my take, 13700f + 4070ti​
13700f has vastly better multicore performance than the 7700, but it's slightly slower than the 7700 in gaming performance...​
...but there's a 4070ti, so to consider the system as a whole - a 13700f/4070ti build would be faster both for gaming and also for productivity applications​
Thank you. I'll ask about the Nvidia difference.
I don't know about the monitor, I haven't started looking. I don't know if I can afford 4k but I need to get the colour gamut right for photography. I can spend up to £500.
I think I worded the budget sentence wrong. I have £2k for the pc, an additional £500 for the monitor. You say 'self build', so these are just component prices? I would love to build it but don't have time to learn a new skill right now (despite having a degree in Ikea ;)) so I'm looking for an OC build. I struggled to get the spec right on the site, eg. I couldn't find Ryzen 9 or a few other bits you've added on.
Hi,
I selected 2 x 1TB as I need a separate drive for photo back up. I could look at cloud back up and would only need 1 x 1TB then.
My basket at OcUK:
Thank you for bothering to reply to my post. ;) Any particular reason you suggest Intel rather than AMD? I'm not planning on upgrading in future given that paying £50 for something now plus £100 for some in future means a total spend of £150 when I could just spend £100 now and get the better item. But I've read of longer support for AMD AM5 compared to the Intel 14th generation coming out soon. I would prefer to futureproof where possible. For that reason I would look at i9 if possible but couldn't find it on the site.
:cry:
For the specific reason you tend to keep your computer for a long time (bar any unforseeable unpredictable component failures)
you are correct, AM5 should be supported to 2025 and will have new CPUs, for intel's LGA1700 socket, the "next gen" 14th gen is simply a rehash of the current gen CPUs
However as you tend to keep your computers for this long (the FX 6300 was released 2012, so you have had this computer for about a decade), then the upgrade for AM5 ie Ryzen 8000/9000 would also be woefully out of date when you next upgrade in what...2030 at the earliest? lol
as i've said, for your use case, the 13700 has more cores and is faster than the ryzen 7000 for content creation: https://www.pugetsystems.com/labs/a...core-processors-content-creation-review-2369/ (i know it compares the 13700k/7700x, but the differences are broadly similar)
the 13700 is slower than the ryzen 7700 for gaming, but this is only when the graphics card is controlled and kept the same for both test systems. for gaming, the gpu is, in the vast majority of the times, the determining factor for FPS, and as such, a 13700f/4070ti build would be faster for gaming than a 7700/4070 build...and by a not insignificant margin: https://www.techspot.com/review/2676-geforce-4070-versus/
you can ask in customer services for a custom build and link them the build
they will charge extra but you do have a 3 year ocuk warranty for the whole build (as usual)
Yes, these are just component prices. I think someone said in another thread that OCUK charge £150 + 4% (of the spec) to build a PC.
I'm not great with monitors, but when I google recommendations for photography monitors I seem to get Asus ProArt and Dell professional monitors, none of which I can find at OCUK.
The Optix seems to be marketed for colours (here):
IPS Panel – Provides 1ms fast response time, optimizes screen colors and brightness.
A content creation level color reproduction of 99% Adobe RGB, 97% DCI-P3 and 82% Rec.2020 by utilizing a dynamically engineered layer of Quantum Dot technology.
UHD High Resolution – Games will look even better, displaying more details.
and this review seemed to think the results were pretty good for a gaming monitor. Except, it was not calibrated well out of the box, which you'd expect a professional level monitor to be.
I think it's likely to not be the one to buy, but maybe you can do some more research, since this is arguably the most important part of your build.
My basket at OcUK:
Total: £2,384.82 (includes delivery: £0.00)​
So far as I know, photography is usually single-core/thread dependent, so I'm not sure how much advantage a Ryzen 9 would offer you and I believe the new AI features primarily use the GPU rather than the CPU.
£315 (incl. VAT)
£245 (incl. VAT)
£80 (incl. VAT)
£30 (incl. VAT)
£120 (incl. VAT)
£108 (incl. VAT)
not sure if this helps but i spec'd a work pc for a mate who uses those and Lumion, it was last gen 5800X and 6800XT (he wanted 16GB VRAM), its been working a treat via a very expensive Dell Pro 4K monitor he bought which cost more than the pc. (and 6800XT's weren't cheap at that time £900?)
Everything helps so thank you. I'm not sure i can afford a monitor that's more expensive than the pc though! :eek:
