Not looking to sell it are you?Whats everyone done with these? Have not heard these get mentioned here yet.
I won one in a raffle and thinking about using it for personal cloud storage but i've seen people set these up for all sorts of crazy ideas.
I wanted to try one as a pfsense box
Not looking to sell it are you?I wanted to try one as a pfsense box
What model did you win btw, the 832?
, currently setting it up for a Personal cloud server.
. The docker OS is pretty awesome too, very configurable!on a more serious note this thing has realtek network ports and everything iv seen to do with pfsense, opnsense etc wont work properly with realtek nic and needs intel.
Isnt it easier to vpn home to samba shares?
That case is a neat idea! did you design it yourself or is there now a zima modding scene?![]()
Cool, I was not aware of the mods on thingiverse, there are quite a lot including a rack mount!
It looks like there is no way to power more than 2x sata SSD's directly through the Zimaboard though, and while there is a pcie to 5x sata adapter you'd need to power the drives with a separate power supply.
Is it possible to power 2x sata SSD and 2x nvme at the same time?
Hehe I know you can power 2x sata with that cable, although the following article suggests they have to be SSD and not HD, which also had me wondering if the native power supply can power 2x sata and 2x nvme all at once, as while you have them available it would not necessarily mean they could all be powered if populated.im getting an adapter soon for this to do just that, its on the zimaboard official website:
I guess if you want more than 2 sata drives you would need a sata pcie adapter in place of the nvme adapter.
www.martinrowan.co.uk
Is a ZimaBoard the Right Choice for Me? - Martin Rowan
The ZimaBoard is a small hackable x86 server, but is its versatility a strength or a weakness, compared to many purpose built alternatives?www.martinrowan.co.uk
When you suggested the case could house 4x 2.5", I saw the pcie to 5x sata on the Zima shop but that does not supply the power afaik and so I was wondering if they could be powered natively through the Zimaboard but the above article suggests you will need an additional external power supply to power more than 2x sata.
, another 2TB drive on the way for more storage option so hopefully that'll be the last piece of the puzzle for awhile.
