Deleted User 298457
Deleted User 298457
As is any wallpaper!
It is, 1903. External walls appear to be solid two layers of brick with no cavity. (No idea of the technical term sorry). I’ll post a pic tomorrow as we have it all showing where we’ve put in the new back door. So yeah, cavity wall insulation is not happening and if we reboard etc we’d be losing a fair amount of space.
Thanks for the link, will check that out.
Apparently it does, will have to be careful with elbows etc![]()
It’s not designed to be fire retardant just as a lot of products in your home isn’t. If you need it to be fire retardant then you would go over it with Fireliner.
ExactlyIt’s not designed to be fire retardant just as a lot of products in your home isn’t. If you need it to be fire retardant then you would go over it with Fireliner.
Wallrock Fireliner (Class 0)
www.erfurtmav.com
Actually I forgot all about this - my mum used to use it when decorating in the 1970's. Polystyrene rolls which went under the wall paper - easy to puncture though. I suspect they have something better these days
This stuff has a felt backing so similar but different. You wouldn’t be able to puncture through it very easily, it’s very strong.Actually I forgot all about this - my mum used to use it when decorating in the 1970's. Polystyrene rolls which went under the wall paper - easy to puncture though. I suspect they have something better these days
Err, to add insulation to your house..Why do you want it?
@targagruba our decorators knocked it up very quickly. Like, probably less than an hour for one wall. But they are super fast and experienced, they were just as quick with our wallpaper and did a great job. Besides getting someone experienced in wallpapering, I don’t imagine you’d need a “specialist”.
I don't think our decorators even charged us for it, and anything deeper on the wall would make our big sash windows with architrave around look a bit silly. I don't understand why it wouldn't be viable. It's better than not doing it. If you're talking in cost terms then we're not bothered about that, we just want to make a terraced house built in 1903 as warm as we possibly can without ruining the character of it.I think there are a number of valid reasons to use it, but adding to the house insulation is not really viable if they are going to pay someone to do it. If you are going to pay someone, might as will have insulated plasterboard put up. Then they end up with it being way better insulated, and a perfect surface for painting or papering.
I'm pretty certain you have solid walls, cavity walls didn't start being buil until the 1930s.
I tried some thermal paint in our hall as an undercoat and it's definitely made the walls warmer to the touch. Every little helps right?![]()
Yes it's a thermal anti condensation paint from Suretherm. I'm not kidding myself that it's made the room warmer, but it's definitely warmer to the touch. Our biggest external wall is in the hallway, so I've used it there. I have some left, so I intend painting an external wall in the bathroom with it, as it's the only wall that isn't tiled. It's quite thick to apply with a grainy finish, and I did two coats, but looks good once over painted. You can of course wallpaper over it if you wish.Replying to an old post I know but since the thread was dragged up anyway, may I ask what paint you used and if you've felt it's made any difference? One of the walls in my son's bedroom is the external wall and it always feel cold, if the paint could help it feel a little warmer to the touch that would be nice as it's right next to the bed.
Thanks for the info, I shall have a look into it as it sounds like it might be quite useful in my lad's room.Yes it's a thermal anti condensation paint from Suretherm. I'm not kidding myself that it's made the room warmer, but it's definitely warmer to the touch. Our biggest external wall is in the hallway, so I've used it there. I have some left, so I intend painting an external wall in the bathroom with it, as it's the only wall that isn't tiled. It's quite thick to apply with a grainy finish, and I did two coats, but looks good once over painted. You can of course wallpaper over it if you wish.
