Why do you need so much RAM?Has anyone managed to get this working with 4 dimms? I have heard that have been some updates but I cannot find anything concrete about it. The only 2 kits I can find are sold by corsair but lean towards intel xmp.
I doubt the Intel memory manager in their CPUs is good enough to support 192gigs, even at very slow JDEC speeds.
If you're not prepared to mess with it manually, I'd strongly advise you don't buy 192GB (which like..., 2 people are using and they both work for MSI).On the box of the ram it does say XMP ready so I hoping it will just "work"
It won’t just work. XMP is technically overclocking and not within the JDEC standard.Thing is I want to be able to game as well. Looking for a jack of all trades.
I was thinking the 14900k with corsair vengeance 192gb rgb on XMP . On the box of the ram it does say XMP ready so I hoping it will just "work"
That’s a 10/10 suggestion right there .Latest ThreadRipper Pro (and Non-Pro) to be announced tomorrow - it'll be interesting to see what RAM they support
AMD to launch Threadripper 7000 PRO and non-PRO Zen4 CPUs, designed for WRX90 and TRX50 motherboards - VideoCardz.com
AMD to launch Zen4 based Threadripper PRO and non-PRO AMD is set to introduce new CPUs and chipsets tomorrow. We’ve just received the initial renders of the upcoming Threadripper processors. It’s clear that AMD is once again introducing non-PRO versions, distinguished by a new packaging from the...videocardz.com
This is a key factor - getting hardware that has been tested and is supported.I actually have just finished testing 192Gb(4x48Gb) of DDR5 5200Mhz (Corsair CMK192GX5M4B5200C38(Ver 3.53.02 - Has to have SN Starting with above 2311 on the first 4 digits) but with a standard Ryzen 9 7950X and it worked surprisingly well. I didnt have an issue at all which i often do with 4x32Gb. This was in an Asus Proart X670E Creator Wifi motherboard and that memory is on the QVL. I have also found that the same memory will work in the X670-P Wifi so that is next to test.
I wonder if it would work with the 7950x3d? did you have to do any manual tweaking to get it stable?I actually have just finished testing 192Gb(4x48Gb) of DDR5 5200Mhz (Corsair CMK192GX5M4B5200C38(Ver 3.53.02 - Has to have SN Starting with above 2311 on the first 4 digits) but with a standard Ryzen 9 7950X and it worked surprisingly well. I didnt have an issue at all which i often do with 4x32Gb. This was in an Asus Proart X670E Creator Wifi motherboard and that memory is on the QVL. I have also found that the same memory will work in the X670-P Wifi so that is next to test.
I like boards like the Creator, they're a good halfway between HEDT and regular boards, though they do have a price tag to match and whether Asus actually test them more (for workstation use), I don't know.This was in an Asus Proart X670E Creator Wifi motherboard and that memory is on the QVL. I have also found that the same memory will work in the X670-P Wifi so that is next to test.
