Should i get a new psu?
19 Oct 2002
Woolyback Country
Specs below
Corsair TX 850 (gotta be 13+ years old)still working ok
AMD 3700x,possible upgrade tp 5800x3D in the near future
6700XT gpu again `possible` upgrade in future depending on price
arctic 360mm AIO,various fans in a HAF 936 case
4 hdd,2 NVME,2 optical drives
Am thinking it is long overdue .What psu should i be looking at?ATX 3.0 i am thinking?long warranty
maybe this?
or this?
Corsair RM850e (2023) Fully Modular Low-Noise ATX Power Supply - ATX 3.0 & PCIe 5.0 Compliant​
:confused:
mmmm that 1000 watter is a bit more than i intended to spend.Retired now and cannot see me splashing out on a 4090 anytime soon :cry:
But as you say it is `only` £30 more mmmm
Will have o think a bit more on this,thanks for the suggestions though :)
I will say I bought a 750W as "you'll never need more", then more modern GPU's started to have spikes in power consumption which made it more marginal. I'm currently using a 1000W which was just a little more for the headroom. Who knows what will be needed in the future or as I did bought a previous gen high end card for "cheap" 6950XT which needs more juice. I'd spend a little more and then you can just forget about it for another 13 years ;)
Found the original deets on the psu
Bought in 2009 for £103.46 :eek:
Will be getting the 1000 watter then i think i have had my fair usage out of my corsair :D
I changed a Toughpower bronze 875w - around 10 years old for a Gold Cooler Master 850w the other day after having a nagging doubt about using an older PSU and older tech.
No difference whatsoever funnily enough other than the fact that the new PSU makes a slightly different tone when under load. Probably didnt' need to bother changing! But then when the seeds are sown of spending more money on these forums.... :D
It's all a waste until it takes out your new shiny ;) The worse issue is if it introduces instability and you spend weeks chasing the issue. I think 10 years is a pretty good run.
opened the bag of cables and noticed a sticker on a sata power cable stating 3.3 ?
Whats this one for? :confused:
All fitted in now,few brown trouser moments.Thought that the cpu to mobo would not fit,was trying the psu end DOH :o
No floppy power so i will have to get an adapter for my fan controller
AND plugged the 8 pin and 4 pin cpu into the mobo (before i only had an 8 pin)....No boot or power.REAL panic time that was:(
unplugged the 4 pin and it has booted and ran 3d mark to test .seems ok so far
