Looking to replace my case and do some upgrades.
20 Mar 2004
I want to replace my PC case, because I'm looking at a bigger AIO cooler.
The case I'm looking at is the Lian LI Lancool III
This is the reason I'm looking to replace my case.
A quick glance shows that the case will be able to take a 420mm radiator, but I want to double check before I go ordering anything.
I could upgrade the AIO to the XT version, I've heard it has better fans, but I'm not sure it's worth the extra price.
While I'm also moving stuff around, I was thinking of upgrading my RAM, using this.
I believe my system can take it. This is what I have currently.
MSI MAG B550 Tomahawk (AMD AM4) B550 ATX Motherboard
AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor
The issues I'm aware of:
  • The overall thickness of the rad+fans (height, in relation to the top of the case and the motherboard).
  • The allowance for the measurements of the rad (length/width).
  • Clearance of motherboard components (e.g. VRM 'sinks).
  • Ram height.
Lian Li's website only gives one requirement, that I can see, which is 75mm max thickness.
Just the £90 would be an expensive kit, £190 seems way overpriced for 32GB of DDR4.
