Amazon Web Services
1 Nov 2007
England
I have a couple of static sites. One of them is hosted in GitHub using GitHub pages but I need to find another host for the other static sites. I was thinking AWS would be a good plan but then I was thinking about how to actually push changes to Amazon S3 to update the website. So my question is as follows: if I create a new git remote repo which points to a Git repo hosted on AWS CodeCommit I could then use AWS CodePipeline to push the changes to Amazon S3 which then update the site. I've checked out prices and it seems quite cheap.
Does this seem like a reasonable option?
Take a look at AWS amplify. I found it very quick to get up and running. Any code commit to github is live within a couple of minutes (a simple Vue.js app). Route 53 for DNS also simple to add.
you can check out cloudflare as well, either just as basic dns / ssl / cache in front of your AWS site to minimise any costs
or using it to do the full page hosting, but might need to rework the site a bit to work with their spec
Cloudflare Pages looks amazing. Thank you. That looks exactly what I want.
