I'm looking for some advice on which GPU upgrade path to go down. I'm upgrading from an AMD RX 5700 (the non-XT version) which has served me well for 3-4 years but is starting to show it's age at 1440p. The rest of my system is AMD, with an X570 motherboard and Ryzen 7 5800X cpu and 16GB DDR4-3200.
I'm torn between the two graphics card options I have -
7800XT - This card has good raster performance, slight future proofing through more memory (16GB), and staying in the AMD ecosystem I continue to exploit AMD infinity fabric.
4070 - Generally slightly better performance, higher price, slight future proofing through ray-tracing.
I also use AMD Link to stream my PC to other devices, although this is frustratingly hit and miss and often just doesn't work at all for no apparent reason. I believe Nvidia have a similar streaming solution in their drivers?
I play in 1440p and usually high-max settings (with a few non-noticable graphics options turned down).
