Hi,
Please can you help me;
I have seen an AIO cooler, but i want to swap the supplied fans with other radiator RGB fans i prefer. The AIO cooler connects into the motherboard via the AIO_pump and CPU_fans headers. The replacement fans i want to use connect to the motherboard via a USB 2.0 header coming from a fan controller.
Because i cant connect the replacement fans into the CPU_fan header, will this be a problem for the the cooling and is this ok to do this?
I am going to build a new PC before Christmas, but at the minute Overclockers has a few parts on pre-order, so i am waiting for them to come back in stock.
Thank you
Thank you
