Quality Bathroom suit suppliers
5 Aug 2006
Kent, UK
Anyone got suggestions for good quality bathroom suite suppliers?
We're redoing our ground floor shower room and looking for a toilet cistern cabinet that has a cupboard above it, i.e. Toilet cabinet that goes floor to ceiling. I'm struggling to find anything like that.
We also need a vanity unit.
We're planning to get the shower unit bits from QX.
Edited to correct poor spelling
Personally when we did the bathroom out I did all the buying from random suppliers.
Victoria plum for a 3/4 swivel door (space limitation)
Amazon for the Shower itself (as it made fitting a million times easier)
Shower tray was from Amazon iirc (delivery fastest)
Bath was from a local supplier (nighon normal width howeever straight walled so a good size)
Sink with undermount drawers, and a extra matching cupboard was from BnQ (cooke+lewis)
Toilet was also from BnQ (cooke+lewis)
Tiles were Wickes for the walls
Tile giant for a contrast tile (stripe up the middle of the bath wall, same on shower wall)
And another random Tile company in team valley for the floor tiles
I think the only bit we didnt supply was the ceiling, we pulled down the old plasterboard ceiling and replaced with that UPVC cladding stuff
I got some units from ergonomic designs, sanitary ware and other bits from drench and some duravit "branded" rimless toilets in the hope they have a strong flush and seen good :D
If you get a towel rail I'd make sure its a stainless steel one to mitigate rust
Id get a shower tray that's stone resin and not that plastic crap. Overall if you' insist to buy from one place drench tends to be high quality items.
I got tiles from porcelenosa
Exactly what tiles are they please? And did you pay a tiler to do it? Looks v good.
They're image white tiles from porcelenosa and I got a tiler to do that but doing my other bathroom
Im gonna be using the same tiles in this bathroom. They're ceramic so will be easier than porcelain to cut. They're quite a soft tile tbh is one downside
