New TV / Freeview box set up
7 Mar 2005
Wolverhampton
Hi all,
My mom's wanting to cancel her £70pm VM contract as she just doesn't watch any of the channels.
She's also got a very old 40" TV which she would like to upgrade at the same time ready for Christmas.
Previously I've installed a Humax box for her but I'm a bit outdated in terms of the tech these days and TVs now being smarter.
Would anyone be able to spec a decent smart 4K TV around 40-43inch and a method she can watch Freeview via a box (or are they all via a TV now?
Cheers!
Has she got an aerial? 99.9% of TVs have Freeview built in nowadays.
Don't believe there is any aerial, just virgin media behind TV.
TV was in a different location when she had SKY, so there isn't any other connection available
Take a look at 4K LG TVs, e.g.
LG 43UR78006LK 43" Smart 4K Ultra HD HDR LED TV £329.99
The Freeview Tuner is within the TV, you don't need a separate box. The above TV has a Freesat Tuner as well (if there's a satellite dish connection available).
She will need an aerial connection. You'll have to get one fitted. Sometimes it's possible to get a signal using a portable aerial within the room where the TV is, or even a proper aerial but obviously this is unsightly.
If you want to research brands there's a list of TV manufacturer websites here.
No manufacturer or retailer is allowed to sell anything marketed as a TV without it having a Freeview tuner. It's mandatory. This has been a requirement since 2008. There's no "99%" about it. If there's no Freeview tuner then it's not a TV, it's a monitor.
At 40" and above, all the TVs will have Freeview HD tuners and have IPTV features, so they'll be Freeview+ sets where they integrate catch-up TV as well as over-the-air TV reception. Question: Does your mum have an internet connection? Does she pay for broadband?
The reason for the question is simple. For UK TV services - the stuff that comes via an aerial, but it can include a satellite TV version called Freesat - nothing broadcast live is better than 1080i resolution. That's the HD standard that Freeview and Freesat use, and there aren't that many HD channels. Most of what she'll watch will be standard definition. 576i resolution. If the plan to change the telly is to get streaming and catch-up services, then that's fine. A new TV will do that. But if the idea is that a 4K TV will look better than the old set for everything, then whoa there horsey. That won't happen.
"Wah?? A 4K TV can look worse?" - Potentially, yes.
Here are the most common display resolutions since digital TV became a thing. We have Standard Def (SD) at 720 x 576 pixels. HD Ready LCD/LED TVs tend to be 1366 x 768 res. Then you have Full HD at 1920 x 1080. Top of the shop for most folks is UHD (4K) at 3840 x 2160 pixels.
There's still a heck of a lot of TV programming that was made at SD resolution. Any time that stuff is shown on a TV with a higher screen resolution, the TV processing has to upscale the image to fill the available pixels. There's a big issue with this. These old programmes were never intended to be upscaled. The pictures don't stand up well. The higher the resolution of the TV screen then the harder it is for the TV to upscale the image. A UHD TV is 20 times the resolution of SD. That means that when an SD image is upscaled to UHD, then between two adjacent SD pixels there's a gap of 19 empty pixels where the TV has to best-guess what should fill that space. This is happening 25 times a second for about 7.9 million pixels each time. That's a lot of maths.
The quality of the scaling is important. The TV settings can also play a part too. An example of this was the F1 qualifying I was watching a few days ago on the canteen TV at a site I'm working at. I think the screen was an LG 43" or 50". Every now and then a list would pop up with the driver's lap times. The text was barely readable. It didn't get much better up close. I had a fiddle with the settings; turned the sharpness down and switched off a lot of the picture 'improvement' processing. It made a big difference to fine detail. The text became a lot more readable.
The rugby was another casualty of poor picture processing. From a distance it was okay, but from 10ft away it was easy to see all the MPEG compression around players.
A new TV will possibly be brighter if you avoid the base models from LG and Samsung. If your budget ceiling is £500 then have a look at the Sony KD43X75WL. After that there's a bit of a jump in price to around the £800 mark.
Where your mum doesn't have an internet connection, (or won't have Virgin is ditched) then think twice about changing the telly. Where the old one is still going strong then a new budget set might be a step backwards.
Regarding access to signals, she'll need either a satellite cable (or two if recording is required) plus a Sat receiver box which itself will be £230. Freeview reception just needs a signal into the TV from an aerial feed. If access and permissions are not a problem then a local installer should be able to rig up a roof aerial plus downlead for around £160. This will be all that's needed if she decides to add Freeview recording (old Humax box?).
TV wise she would be fine with 55 inch for around £350 max. (when it comes to these tv unless you are willing to pay close to grand the low budget say £350 is not any different to £500-600)
As others have said all TV include freeview built in.
I would pay to have aerial installed external you are looking at under £200 for this.
Another option is run a new cable from sat dish to allow free sat some tv have this built in or you could use separate box for that these can be picked up for under £50.
No need to do any recording anymore with the likes of catch up tv.
Having recently had to sit through a program on the Channel 4 app I think recording is still absolutely an essential due to the hellish amount of un-skippable ads. Also, more time to watch any recordings and simpler and more convenient to just have a list of all your recordings in one place rather than having to hunt across multiple apps to find whatever you wanted to watch and keep track of when new episodes\series of shows you watch appear on the app.
A lot of sets will have a satellite tuner built in (DVB-S or S2 as opposed to DVB-T which is freeview) mine does and wasn't a fortune as does the one I picked up for mothers place you just select channels on the remote just like freeview but a better picture + more HD channels
This is incorrect it's a requirement in this country for a TV to have freeview tuner as standard not freesat.
dvb-t2 has been standard for over a decade.
DVB-T2/T/C/S2/S tends to be available on most modern sets with some very low budget ones only missing S2/S or T2 if it's non HD
I meant you need to look in the specs of the TV set for DVB-S(2) if you want satellite as not all will have it, obviously they have DVB-T(2) or they wouldn't be able to receive anything
Bump.
Im in a similar situation with my parents. They do have an aerial though and a sky dish (that’s just been cancelled).
So it’s my job to find them a Freeview box. They require it to be able to record a few channels at a time. A “sky like” interface would be nice.
Help :-)
