Google Pixel 8 Vs Google Pixel 7 Pro
24 Oct 2023
United Kingdom
Hi,
I have the opportunity to purchase a brand new Google Pixel 8 (standard) or the Google Pixel 7 Pro for £490 each.
Firstly, would you consider £490 a good price for either phone brand new?
Which phone would you consider a better purchase for £490?
I don't play games.
I don't customise anything.
I would like to take good quality photos when I visit new places and I understand the Pixel 7 Pro would be the best choice for that, but I would only point and shoot, I wouldn't play around with camera settings prior to each shot, if that makes a difference.
The longer life support of the Pixel 8 is a plus.
Robustness is crucial too. I don't abuse my phone's but in case it is dropped, I would like the phone to remain in one piece. Would the Pixel 7 Pro's curved screen be likely to break?
Does the new Tensor G3 on the standard Pixel 8 make it a better buy or is the better camera on the Pixel 7 Pro is the bigger plus?
Thanks.
25 Jun 2007
Downtown
If you value the zoom a lot then I'd say get one of the pro models. Otherwise the 8 over the 7 pro thanks to the much improved Tensor G3 and OS updates. Screen is also brighter.
25 Jun 2007
Downtown
I'm not sure how much I'd value the telephoto lens as I've had/used a phone with it.
Cameras on the 8 vs 7pro are pretty much the same bar the telephoto.
8 pro has the much improved ultrawide cam. Get the 8 Pro if you can and plan to keep it for a long time. 5 years should be easy if you're not too fussy.
26 Dec 2009
Norwich
Or pixel 7? it's still a really good phone the 8 wasn't a massive upgrade over it. good size, not too big. battery life is the same tensor 3 brought no more battery improvements. You can pick one up for about £370
