- 4 Aug 2007
- Wilds of suffolk
Solar panels and battery - any real world recommendations?
I'm talking about excess power not power you need, and in the saving sessions it will be 100% worth exporting as much as you can even if you wind up using the grid later on that day, because the payments for exporting then will far out weigh the costs of importing.forums.overclockers.co.uk
The post I think you're looking at is a 5.2kwh battery, so £1,000 odd of battery less.
Add that and take off £700 of panels and it's somewhere actually pretty close to the same ballpark figure.
Sure, in an ideal world the labour costs would be much less, but I think that's the issue I'm hitting here, in that the labour figure for 6 / 13 panels is going to be pretty similar.
Being a mid-terrace, I can only fit the 6 on the S facing roof. Might fit another 4 on the rear if I was lucky, but they didn't suggest any on there.
Doing some skimming on MSE, it seems to suggest that a battery is pointless (export the excess!!!), but interestingly the numbers he was showing me suggested the battery to be a considerable part of the benefit.
FWIW, total daily usage is ~8kw
I can recommend the guys that did mine.
I will send you a message later with the details.
They have some kind of loyalty thing but I am not sure how it works I never really paid much attention to it.
But I will include details so you can include my name. They are Norwich based btw.
However I would consider the main systems that install are Solax based (they do do GE as well but complain it takes ages on site sometimes to get them commissioned)
