I may be strong becayse I haven't installed Superposition in a long time but I'm pretty sure they changed that with it. Hence the reason I've stuck with Heaven for all these years.Ignore what the table says - Valley and Heaven both run constantly anyway in a demo mode (not sure about Superposition)
Unigine Superposition although you dont exactly say what you are stress testing, an overlock? an undervolt ? a stock card but then again why do you want to stress a stock card ?
Heaven and the above would always give me a guide as to whether my OC was successful or not.
Does it matter?
Yeah but stable is stable regardless of use case....In case the response needed tailoring for a specific use.
The 4 year old in me loves that!
What would yoy recommend to test stability for a stock s vs an overclocked vs and an undervolted system?
I believe Furmark/Cinebench is the most common 'murder your system' loadI'm now looking to test how my case and AIO copes with heat - what's the best way to stress burn the GPU and CPU at the same time?
For example, is there a GPU test I could run at the same time as Cinebench R23
I believe Furmark/Cinebench is the most common 'murder your system' load![]()
I loop the Metro Exodus EE benchmark tool. Furmark & Kombuster is fairly useless outside of just cooking your cards VRMs
Wait until a really hot day in summer (unless you have AC) and use it like you normally do but with something like HWInfo running to see how close it gets to throttling.I'm now looking to test how my case and AIO copes with heat - what's the best way to stress burn the GPU and CPU at the same time?
