- 12 Feb 2006
- Surrey
we've had a minor leak from our flat roof for years, never been a major issue as it happens infrequently (about 5/6 times a year), and it happened in what was a car port, then a utility, but now it's been converted into a second kitchen for our tenants to use and so is more of an issue now for us to sort.
the flat roof is of weird plastic membrane material (almost like a really thick black bin bag) rather than felt. we've tried painting on this very thick grey "paint", which seemed to work for about 1/2 years, but it's leaking again, and i've tried to repaint it on this weekend, however the leak is still happening and the roof is rather slippery at the moment so it was hard to get it to stick, even doing a clean before hand (limited to how much i did due to the poor weather)
i'm looking for advice as to what else we can do now.
the ceiling in the 2nd kitchen is wood planks, and we've taken down a few in the spot it leaks. you can see the water runs directly down the beams side that's directly above the wood planks, however above that is what looks like chip board and you can't see the water source there and obviously water can run along anything to find this spot. it should be said that directly above the leaking spot is the join for a few of the plastic membrane where they all meet. this initially led me to believe it has to be the spot where the leak is coming from, but i have painted so much of that grey paint on this spot over the years you can't see the membrane any more.
i'd rather not take the whole stuff up and start again as the area is large, with it covering out kitchen, WC, study, large garage and 2nd kitchen.
any thing you can suggest i could try to try fix this?
i'm considering putting something above the ceiling wood planks to try and catch the leak before it gets all the way through, and then redirecting that else where, though no idea where
