- 29 Aug 2010
- Cornwall
So, I've got two 4K screens (PHILIPS Gaming 279M1RV) that I use with my PCs. They're not great but good enough I can't justify replacing them yet.
My issue is I also want to use them with my work laptop when I'm WFH. This is an issue because my work laptop doesn't support running 2 4K monitors. I'm not 100% if it will even do 2 @ 1440p. It does support one 4K monitor though, which is what I currently use, but I think I'd rather use both monitors at 1080p (even though it's effectively half the space). I cannot get it to do that though. I believe the problem is that it can't do 1 4K and 1 1080p, so even if I set 1 to 1080p the other one won't display anything, I believe because it's trying to run the other monitor at 4K and I can't stop it until it's recognised and is using the monitor.
Are there any other ways of limiting it to 1080p? Can you get a HDMI 1.3 cable or will that likely work as HDMI 1.4 and do 4K @ 30Hz? Everything that looks like it does 1080p MAX also seems to do 4K @ 30Hz.
Anyone got any ideas?
