Love that! Looks great!Got around to a test build in my case last night. Still waiting for upright GPU mount kit, 90cm riser cable plus distro plate, custom loop etc. So tried out the vertical mount with an AIO for now.
Finally a case that makes the 4090 strix look like a normal size GPU
Case is a pleasure to built in, very solid construction. Though I do wish the HDD mount cages would have been an optional extra. I exclusively use NVME drives for my gaming rig, so these are a complete waste. Also they spent time in the factory routing the SATA power and data cables for 4 SATA drives, which wil be wasted expense for many. I ended up removing both cages and their associated cables to have more room for cable management.
Whoever thought that NOT including the upright GPU bracket (£5!) and including these cages/cables should be shot![]()
Just put My order in with EKGot the P420M rads installed today x3 along with the front distro. Should look good when finished hopefully
Its the LIan Li vertical mount. Didn't see any mention about it being compatible or not with Matrix 7 in the manual so will be P****d if that turns out to be the case, they also failed to mention that you cannot have the fans on the inside of the side rad for it all to fit. I have since had to move the fans to the back side of the rad which suck aesthetically.Just put My order in with EK
going for the same thing but not using the side Rad,
Did you paint the Vertical mount yourself or using the Lian Li one?
EK told me the Lian Li one wouldn't work with the distro plate under matrix 7 so you had to buy theirs!
I had a air cooler in it recently, it looked fine. The main thing is populating it with 140mm fans IMO.I have used the 011 Evo air cooled with front mesh. It is very quiet with lian li infinity fans. The 011 XL will look stupid air cooled because of all that empty space
I went fan overload I had 1 120 rear, 3 120’s top, 3 120’s bottom, 3 120’s side and 3 120’s front.I had an air cooler in it recently, it looked fine. The main thing is populating it with 140mm fans IMO.
13 fans total
Here's my Gaming/Media setup!
Specs:
4090 FE
7600X (Waiting on 8 core next gen CPU)
X679e MSI Carbon Wifi
32gb DDR5 6000mhz Fury Renogade RAM
Lian Li Evo XL
420 D30 Phanteks Glacier One
140mm D30 x 6
120MM D30 x 2
Storage;
WD 750 2tb Nvme
WD 850x 4 tb Nvme
WD 850x 2 tb NVMe x 2
Crucial MX500 4tb x3
Crucial MX500 2tb
Connected to
77 C1 OLED
Dolby Atomos Surround Sound 5.1.2
