- 14 Nov 2023
- United Kingdom
7900xt working great, all in the clear. Thanks all.
sounds like exactly what my issue was only way to stop it is underclock the card (retest to be sure) or rma it. mine was out of warrantyDisabled the integrated graphics, no luck
Ram as noted when unstable can cause issues that are hard to pinpoint.Can't keep up with this, crashes started again last night i.e. went back to can't play for more than 5 mins. Saw someone had mentioned the memory and disabling EXPO which I did and bingo 40 mins and cyberpunk 1hr on Breakpoint. The memory is running at stock though now 4800mhz, not sure how happy my 7800x3d is about this. Has anyone had this before, should i replace the memory?
If you dont know what your talking about, dont make suggestions you dont understandProblem is win 11
Go back to 10
