Hi all,
Recently upgraded my Virgin to Gig1, and noticed right away I was 'only' getting 700Mbps on my wired devices. I've managed to pin point the problem to the Tenda Nova master node, as plugging my unmanaged switch which is directly behind the Nova directly in to the Virgin hub then gives the full gigabit.
I've been happy with the coverage and general performance of the 3 node Tenda Nova system I have, but its a good few years old now and while the Wifi speeds are perfectly servicable, its probably slow compared to whats available these days, and with this apparent limitation of the supposed gigabit lan port on the Nova limiting my speeds, I have been thinking about an upgrade.
As a side note, you're probably wondering why I don't just plug the Nova in to unmanaged switch instead, I did try this, however then some of my devices were not able to get an internet connection, possibly due to issues with DHCP IP assignment? I'm not 100% sure, but I wasn't able to solve the problem, and went back to plugging the Nova in to the Virgin hub first, which then allowed all devices to connect again, but limited to 700Mbps.
Any suggestions on a mesh upgrade, or network reconfiguration appreciated!
