We have life! It's a massive relief to me that it's working and there are no major problems with it. The biggest trouble I had was with the Windows 11 install - had to do a work around to get it to install in the first place then another to get it to install offline. Windows 10 was not this much hassle. Anyway Google came to the rescue and all is well on that front.
Haven't sorted out the rgb on the RAM sticks and see anywhere in Armoury Crate/Aura to do it. More Google work I suspect if it continues to bother me. I'm probably going to to ditch the Aquacomputer LED strips at the bottom of the case or maybe just leave the one at the back of the radiator for a bit of ambient glow. It's not something I'm getting my knickers in a twist about just yet. Just happy that it's all functional. Also the case leds stuck on rainbow - no way I can see to adjust them.
Spec is as follows -
Case - Lian Li O11 Evo XL and vertical GPU mount
Motherboard - Asus Rog B650E-E
CPU - AMD 7800 X3D with TechN waterblock
GPU - 4090 FE with Watercool heatkiller V waterblock
Ram - 2x16 GSkill Trident Neo CL30 6000Mhz
Storage - 1TB Seagate NVME drive, 2TB WD NVME drive
Fans - 20mm be quiet! Silent Wings Pro 4 x 10
Rads - Alphacool Nexxos 360mmx45mm
Res and Pump - Aquacomputer Ultitube 200 and Aquacomputer D5 Vario
Tubing - mix of Watercool heatkiller EPDM and Tygon EPDM
Fittings - mix of EK compression fittings ands drain valve and Bitspower 45 degree, 90 degree, extensions etc. Also Bitspower water temp sensor
Flow indicator - EK
Fan control etc - Aquacomputer OCTO
LED strips - Aquacomputer
Power supply - MSI Meg 1300W
Thanks for all the help and support guys - made a massive difference to me.
