- 12 Feb 2006
- Surrey
I have spot lights in my lounge that I never use as they are the old yellow style ones that are higher power usage and are dimmable.
I do however have a load of unused hue smart colour gu10 which fit in the space, however they don't join the connected inside. I'm told I need to upgrade each light fitting converter (perhaps they used another word) and change the switch to a normal on off rather than dimmer.
Anyone able to give some more guidance on what it is exactly I'll need to do?
I can post photos if it helps
