perfect time to read this…Looking good!
Really need to try my hand at sleeving. Knowing me though i'll blow something up or blow myself up.
Yes, the normal cables are about 5cm to long, except for the twin 8pin to NVidia 12 pin which was 20cm too long, and needed a whole loop around to fit. There was also a 60cm SATA with 4 plugs which is now one @ 15cm.What are you doing with the custom cabling, just making it shorter to fit in the build better? Looks fantastic, very shiny indeed.
Thank you.I've never seen a case like this before, I must say it looks incredible. Your attention to detail is outstanding
It’s the Streacom DA6XL. https://streacom.com/products/da6-mini-itx-case/ or https://www.overclockers.co.uk/stre...pen-frame-steel-pc-case-chrome-ca-062-sr.htmlWhat case/chassis is it?
It’s currently running a 24hr Superflush. So close to done nowSuperb work and I hope you get it all reassembled and it posts for you in the not too distant future.
Thank youHats off to you!
There were times it got very close to running outI envy your patience!
