Hello everyone
First off I would like to wish everyone a happy new year.
I mainly play on the Xbox series X and really enjoy playing DayZ, so have been considering moving over to PC but I know nothing about what is the right PC specifications for a build (I have looked at the required specs on the internet but seeing as I don't really know a lot about building PC's so will get one pre built or input my own parts on custom PC build)
So I looked at the requirements on the internet and in the spoiler is what it says hopefully it's upto date
Intel Core i5-4430
RAM:
8 GB RAM
GPU:
NVIDIA GeForce GTX 760 or AMD R9 270X
DX:
Version 11
OS:
Windows 7/8.1 64-bit
STO:
16 GB available space
Sound:
DirectX®-compatible
Intel Core i5-6600K or AMD R5 1600X
RAM:
12 GB RAM
GPU:
NVIDIA GeForce GTX 1060 or AMD RX 580
DX:
Version 11
OS:
Windows 10 64-bit
STO:
25 GB available space
Sound:
DirectX®-compatible
I would want a full build from PC, mouse, keyboard, monitor with a good sound card and not just onboard. I have a steelseries 9x headset which I use on the Xbox although I don't think it's too great in my opinion as I find it hard to pinpoint where the sounds are coming from or it could just be my poor hearing
A few things I've been told by other PC players on discord is the following:
Ryzen 7 7800X3D seems to be the best gaming cpu
For RAM you’re best getting around 32gb over 16gb
Get the fastest SSDs you can afford at least one fast one for your games.
I would consider your monitor also 1440p with fast response time 1ms
I would like the PC to be quite future proof so I'm willing to spend around £2-3k max so that it will last me a long time, now that is probably an overkill budget for a game like DayZ. It doesn't have to be the whole budget spent just a good enough PC that will last a while, the cheaper it is the better for my wallet or for the wife to spend
but you get what you pay for at the end of the day.
Regards,
Gary.
Minimum system requirements:
CPU:Intel Core i5-4430
RAM:
8 GB RAM
GPU:
DX:
Version 11
OS:
STO:
Sound:
DirectX®-compatible
Recommended system requirements:
CPU:Intel Core i5-6600K or AMD R5 1600X
RAM:
12 GB RAM
GPU:
DX:
Version 11
OS:
Windows 10 64-bit
STO:
Sound:
DirectX®-compatible
Regards,
Gary.
