- 31 Jan 2022
- UK
Think thats being mugged ? had a quote to clean the gutters £290.00
My brother had a quote of £3000 to clean the roof.
Hello!
I had new gutters fitted by a really rubbish fitter some years ago. Wonky and with clips missing. Additionally there are some loose tiles on my roof. One part of the gutter is leaking.
Someone was doing some work next door so I asked if he'd be able to fix the leaky gutter. He recommended removing and re-seating the gutters properly and reseating everything to slope correctly. I got the impression he'd do a good job and he's locally recommended.
For removing and re-fitting the gutters (front and back of a 8m wide house - so 16m of gutters) and fixing some tiles on the roof he wants £450.
I've a feeling that's a lot of money but also conscious the work needs doing. Would really appreciate your advice.
Thanks
Not sure what covid has to do with it, it's never been cheap if you are getting someone in who knows what they are doing.Just cause you've received a day light robbery quote for essentially using a brush, doesn't mean the other quote also isn't daylight robbery. Sadly the whole industry is.. Want it done cheap, do it yourself or appreciate that they all put up their prices a stupid amount after covid.
Yeah I've heard not to jet wash or use any chemical treatments as it can cause more problems in the long term.
Probably best just to get up there with a trowel or something and remove any moss by hand.
How is some anecdote about you fitting soffits, gutters, roofing tiles and windows relevant? You were not paid 450 a day as a lad on a building site? lmao sign me up...id happily be a gopher for that money. People pay trades to do jobs because they have the knowledge and can do it in a quicker timeframe than joe public.I've fit sofits, gutters roofing, tiles, windows. I used to work on building sites as a young lad. It requires a drill, ladder, screwdriver and time. Apparently that time cost 450 a day and I most certainly was not paid that. Even £225 a day is expensive if it took 2 days. You work it out. I'm not gona argue with you, it's my opinion.
It doesn't help when you have programs like Rogue Traders, the public have a warped view that every tradesman is out to rip them off.
Nevermind too much Colin Robinson energy
Hello!
Thanks
particularly re-felting
