- 2 Jul 2019
Thought i'd ask to see if there's a common solution to the following USB issue, as opposed to it being unique to assrock bios.
Board is a B550, but a different B550 as well as other boards i've never had the issue.
At first it didn't happen for a handful of boots upon a windows reinstall, now it's every boot. From cold boot a plugged in USB soundcard fails to be recognised in Windows as connected, upon reinserting when Windows had loaded it shows up. Fresh Windows install currently, but this was happening before the reinstall.
There's a driver available unique to the soundcard, with or without, no difference. I've had a play with the USB suspend settings.
Is there a common solution to the USB issue that anyone knows of?
I seem to be unlucky with B550 as this is a second one that has caused me strange issues. Yet my Mortar B550 has been rock solid even running a 2600x perfectly (all tested internal headers work, BT and Wifi work).
