Needing a new PC, last built mine 10 yrs ago...
4 Jul 2004
LDN
Hi everyone.
Happy new year!
So im currently using an i5 - 4670K running at stock, with 16GB RAM and an RX550 , and a samsung 840 evo SSD. Its not used for gaming and is rock solid, and Im using it to work from home, currently running 2 x 27" 1440 p monitors.
My son needs a PC for his school work, so will be passing it down to him.
I will be keeping one of the screens above and adding in 2 x 32 inch 4K monitors. I believe the RX550 will be capable of running both 4k monitors at 60hz and the 1440p screen all together at the same time.
This will 99% of the time be used purely for windows based applications/working from home; I need multiple windows open while working, hence 3 screens. The applications are not too intensive so i suspect I should be aiming for 32GB of RAM to future proof. I leave all gaming to my PS5 but would be tempted to dip back into PC gaming if there was an FPS title that would get me excited (like a Half life / Quake title etc) so I would like the base spec to be solid to allow a good graphics card option in the future.
So looking for CPU, Mobo, RAM, SSD (or M2), Case (with USB-C for future proofing), PSU, quiet heatsink/fan
The case will be mounted onto a secretlab magnus pro xl desk using their own PC mount, with allowed dimensions below
  • Height: 354 - 543mm (14.0 - 21.5")
  • Width: 170 - 300mm (6.7 - 11.8")
  • Weight: Up to 25kg (55lb)
Budget £500-£700 - although would like to keep it as cheap as possible.
thanks in advance
My basket at OcUK:
Total: £647.88 (includes delivery: £7.99)​
The case doesn't have USB-C, but the motherboard does on the rear.
I'd recommend switching to the 13500 if you can get it for a reasonable price, it has a better IGP and 4 more E-Cores.
The motherboard has 2x DP, 1x HDMI and 1x D-Sub. In theory, you should be able to use all of them together (Gigabyte's spec says quad display is supported), but I think the pipes may be shared, so the more bandwidth you use (res + refresh), the less that is likely to work.
quiet heatsink/fan
The bundled one is fine at idle and if you turn the turbo off, but it will be noisy under full load, so I'd suggest something like this, which is one of the best value air coolers you can buy.
My basket at OcUK:
thanks for the reply. Im so out of date with processors - I was under the impression that IGPs werent great as it made overclocking harder? I take it these processors are locked too? I have seen the 13500 at a similar price of the 13400 so would be tempted. The specs on gigabytes website do state 4k 60hz simultaneously.
Regarding the case, im quite happy to go for something a little bigger or more solid. I currently have a bittfenix prodigy and its a pain in the arse to open up when something goes wrong. The thermalright looks great, i suspect it will fit a micro-ATX case fine ?
I don't think they have a big influence on overclocking, but you can't overclock a non-K CPU on a non-Z board anyway (except for removing their power limits). If I were you I'd prefer it over keeping the 550, for the simplicity and lower power usage of a GPU-less system.
Yeah, but be careful of the case max height and motherboard VRM & RAM clearance, especially on a 2 slot board.
I have a few cheap Aerocool cases and they've been fine, very thin metal, but sturdy enough. Your call :)
Im assuming the thermalright is fine in the aerocool case then ? its a nice case and nicely priced.
It will .
The fan speed on the aerocool case are not controlleable and run loud they have priority connections , I believe you can get a controller but can't remember if that's just for the RGB.
@Wing-Man knows more about this , I'll send out an SOS
It will .
That’s a shame, I saw they run on molex and not 3 pin, but you can’t get everything at that price !
True.
See what wing man says I think the controller is only £5
Alternatively 3 x 120mm arctic pwm fans cost £15 , the pst you can link together so they connect to one 4 pin header .
Theese are f12 fans more suited as case fans the p12 have higher pressure/ airflow..
True.
I have two Noctua NF-P12 redux-1700 PWM Fans unused, so may hook these up instead. Ill await wing man's input
@Tetras , the Crucial P5 and PSU seem to be out of stock. Any suitable similarly priced alternatives you can recommend ? TIA
Hmm. MSI 480 Pro or Kioxia Exceria Pro are the only similar drives (high-end PCI-E 4.0) that I can see, but they're £10 more. You could go dramless and get something like: NM790, SN580 or SN770.
PSU: Seasonic GX-650 is £5 more, or you could get the GX-750 or Corsair RMx750 for £110.
It will .
@Wing-Man , any thoughts on this, would really appreciate your feedback. . is there a controller to control the speed of the fans ?
ive used a few and its hit and miss TBF, my 2 sons both had(had) the aero one, one of the controllers dose work and one dose not. but i wouldn't say the fans are loud unless you putting it on your desk
they do have a priority connections, i have a controller spear if any wants one lol..
I might take you up on that - any details on the one you have spare ?
