Hey Guys,
I bought the following last year from OCUK
GPU - Description: Gainward GeForce RTX 4090 Phantom 24GB GDDR6X PCI-Express Graphics Card
CPU - AMD Ryzen 9 7950X Sixteen Core 5.70GHz (Socket AM5) Processor - Retail
PSU - ASUS ROG THOR 1200W 80 Plus Platinum II Modular Power Supply
Cooler - Lian-Li GALAHAD AIO 360mm High Performance RGB CPU Water Cooler - White
Ram - Corsair Vengeance EXPO 32GB (2X16GB) DDR5PC5-48000C36 6000MHz Dual Channel Kit - Black
Mobo - Gigabyte X670 Gaming X AX (Socket AM5) DDR5 ATX Motherboard
I've noticed that my bios version is saying F2 which is really old.
I've tried updating to f20 but after the process is complete, I'm just left with a black screen and a red DRAM light on the motherboard.
When I reboot my bios version is back at F2.
I'm just looking for some advice as the posts and information I'm finding online is conflicting.
-Is there a specific version of the bios I should be going to from f2?
-Should I try this with a single stick and bios settings defaulted?
Any advice or guidance would be really helpful thank you!
