If they are not there to "check on the reliability of the evidence" then why does it say "They must consider whether the evidence can be used and is reliable." on their own website? To make it worse that statement is actually from the 'Principles' section lol
The principles we follow | The Crown Prosecution Service
www.cps.gov.uk
***Facepalm***
You do not understand what is meant by "check the reliability of the evidence".
It means, is the source a reliable source? Is it circumstantial? Has process been followed?
Does the witness statement that the entire case rests upon have a history of perjuring themselves?
Is the evidence weak? On thin ground? Easy to dismiss in court? Is it likely enough to secure a conviction?
It does not mean, set up your own investigatory body and re-investigate the case to see if the Police or Post Office's evidence is complete and accurate, and all there is to know.
As @Sythe79 said:
There's a difference between checking evidence is reliable and ensuring there is enough reliable evidence.
You either do not understand that difference, or you do but don't care.
The investigatory body presenting the evidence were in the midst of a coverup and were withholding vital evidence from among other people, the CPS.
So for the third time...
What actual action, that was within their remit, do you want the CPS to have taken when presented with evidence that turned out to be strong enough to secure a conviction? Why can't you tell us?
