Some do, yes. Go to the support page for the board for details.Do these new motherboards require a bios update for the 14 gen cpus?
Regards scubes .
Some came with WiFi 7 as well as I recall?Very much board dependant - just browse your mobo support page for info - often you can decipher from BIOS revisions history.
There had been some more MOBOs released after 14gen went live which should already cater for it out of the box.
B760M Gaming Plus is one of those boards, I believe. Odd MSI didn't give it a MAX label, like they did with the other ones.There had been some more MOBOs released after 14gen went live which should already cater for it out of the box.
Dark Hero: should be "out of the box" compatible (see here *).I'm maybe gonna go for the asus hero dono if it will require a bios update if so no go ...
* https://rog.asus.com/articles/maxim...og-pave-the-way-for-14th-gen-intel-core-cpus/In total, we’re releasing six new Z790 motherboards for your consideration as you hunt for the best motherboard for your 14th Gen Intel CPU. Our cutting-edge ROG Maximus motherboard family is expanding with the ROG Maximus Z790 Dark Hero, the ROG Maximus Z790 Apex Encore, and the ROG Maximus Z790 Formula. For gamers everywhere, we’re expanding our ROG Strix lineup with three new models.
In my opinion: Asus are charging silly money for a guaranteed bios update, across their entire range. Unfortunately, they only include USB flashback on Strix models, so the older, more affordable TUF and Prime Z790 boards are not an option.Just had a look at the dark hero 700 odd na to expensive foe me
It’s very cool tech but very early days and if you’re not going to upgrade your router over the basic one from your ISP, don’t worry about it.Why would Wifi 7 be a consideration at this point? You'd struggle to see capable routers and internet providers by the time you change (5 years?) to really take advantage I'd imagine.
