Sounds about right.worked out roughly £1697
PCI-E 5.0 drives are very expensive and it is pretty rare that storage is a bottleneck, though with your usage perhaps it makes sense.Check out team please advise
No gaming? If so, then the A750 is understandable.Mainly used vid editing upscaling etc
You might want to look at the 14700K, though it would limit your motherboard options (Aorus Elite can be BIOS flashed without a supported CPU).Asrock z790 riptide wifi
intel i7 13700k
