AMD X-Connect? Smart Access Memory unsupported?
12 Sep 2003
Newcastle, UK
Hey
Any ideas on these, I'm a bit confused. :confused:
1. I appear to have x2 GPUs available to me? Should I disable this and if so, does anyone know how. Is it coming from my CPU?
https://i.~ibb.co~/NS7zxmV/GPU2.jpg
2. I have this new system tray icon since updating my drivers, what is it and what does it do?
https://i.~ibb.co~/NZJfNyG/X-Connect.jpg
3. Smart Access unsupported. I'm sure this was working on my 6700XT in my Asus board. Does it not work with 6900XT on ASRock boards? Or is it to do with the fact I have x2 GPUs running?
https://i.~ibb.co~/QbtYCW6/Unsupported.jpg
Thanks for any help!
Thanks @Tetras. Glad to hear it doesn't matter, my first thought was that is the reason why Smart Access Memory was unsupported. I'll go and double check the BIOS now thanks. With regards to the XConnect icon, what do you mean Graphics via USB4/Thunderbolt. Is it just a feature of the board that the driver has detected and made available?
Cheers.
Well I checked BIOS, and both Above 4G decoding and Re-Size BAR support are enabled. Above 4G MMIO limit is set to 40bit (1TB). Rebooted and now it is showing as "enabled". WTF.
https://i.~ibb.co~/6017Zxt/Supported.jpg
:eek:
