PSU for Ryzen 3600x and GTX1060
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
A good quality 550w psu from a reputable brand will be more than enough for that set up. However, should you upgrade to a more powerful gpu in future you will also more than likely need a bigger psu so it may be worth buying one with the potential to cover future upgrades.
OP
10 Apr 2015
Hungerford, UK, Earth
what about this one for the price?
My basket at OcUK:
Total: £44.99 (includes delivery: £0.00)​
Man of Honour
12 Jul 2005
The 600/650w psu's have always been a sort of limbo in that they are ok for a mid range gpu but would most likely need replacing if you upgrade to a more powerful one. Personally I wouldn't buy that psu. It's a low end Tier C unit with cheap internals. I can't remember exactly who the OEM is but it may be HEC and I wouldn't touch one of their units at all. It will power your pc and I suppose it's better than a Kolink Core series or other cheapo psu but I wouldn't buy one and I won't recommend something that I wouldn't use myself.
13 Mar 2010
if you want to upgrade in the future i would get a 850w from a decent brand like seasonic who make their own https://www.overclockers.co.uk/seas...w-80-gold-modular-power-supply-ca-08m-ss.html
or if you dont need the pcie 5 connection yet but can still use 2 x 8 pin for the adapter that comes with new graphics cards then i would get this https://www.overclockers.co.uk/phanteks-amp-850w-80-plus-gold-modular-power-supply-ca-0ar-pt.html which is also made by seasonic with a 10 year warranty too
OP
10 Apr 2015
this is for a budget build for a friend from mostly second hand parts, they wont be upgrading to a higher tier in the future, that PSU is more than the motherboard and CPU put together
Man of Honour
22 Jun 2006
If the be quiet follows the reviews of similar models (can't find a review of that one, specifically), then it'll have lower quality components than the tier A-B models, which might impact the PSU's lifespan (especially @ high temperatures) and it is probably based on an older design that is less suitable for modern systems, but since it claims to have DC-DC, it suggests the design is relatively modern. It also has 2x PCI-E 6/8 pin and 1x EPS 12v, so the connectors aren't ancient either.
I suspect these are just designed/intended for custom builds to be no-fuss PSUs that meet their warranties and maintain a competitive price for the more marketable parts of their build. So, as pastymuncher said, it is likely to be better than most of the cheap junk out there, but would I use one in my own PCs? No.
2 Jun 2014
Solid 550+ PSU. Typically I go gold rated but if it's for a budget build a bronze rated from a reputable brand should be fine. 850w seems overkill for me.
