Help me find a dance song
12 Feb 2006
Surrey
Well I assume it's considered a dance song.
One issue I have is that it has zero words, or at least if there's any words, there's maybe 2,but I'm pretty certain there's none.
The only way I can describe the song is it has a similar bhwong noise as to that in interstaller, and it's played throughout the song, at different speeds and pitch, but it's essentially just goes like
"bhwong, bhwong bhwong bhwongggggg, bhwong bgwong bhwongggggg"
Help me find it :p
Neither suggested so far.
Might be a long shot, this one ?
I guess this is kind of similar to the noise, but each bhwong is longer and drawn out. Imagine more like each time you hear bhwong it takes 2 seconds to say, and then sometimes on the 3rd time it's like 4 seconds to say it.
Do you know what sort of era this song is from to narrow it down a bit?
All I know is it plays on kisstory, but the play some modern songs mixed into the play list so not sure how much that helps. I feel it's more modern than the infinity and insomnia songs. Perhaps within last 15 years
Perhaps around avicci time
Try the playlist:
I did, even when it was live and of course they show the song before, and the song after, but not the song I was after, and it was too brief for my Pixel to pick up what song it was
Joseph Ashworth - Trooper
Or his Breathe, he does sound like he's influenced by Hans Zimmer
Google search on mobile allows you to hum it a tune, give it a try, it does work.
