My sofa is denting my floor that I spent forever sanding. What's the consensus on castors etc?
19 Aug 2019
I don't want my sofas to be in the same place all the time; I slide them back and around a bit so I can film things in my flat and a lot of the castors / furniture pads are "no slip."
Also they seem to be to prevent scratching when what i have is dents from pressure.
I've ordered some castors from amazon but, to be honest, I'm skeptical they have enough surface area on the bottom to spread the weight enough.
Also; points for anyone who can tell me some sort of trick to getting these dents out or less noticeable without sanding the floor again. I can't sand the floor again. My hands hurt for a year after I did it.
I think the castors may just cause bigger dents. It just how soft the floorboards are, i assume they are pine.
You could try heating the dents with an clothes iron, cloth on the floor first.
we inherited from the inlaws when they passed a sofa with large plastic cups we call the elephants feet. the castors fitt in them and they distribute the wieght about 3 inches in diameter. i think they purchsed them seperate maybe look online?
similar but larger https://www.rosscastors.co.uk/brass-castor-cups.html?msclkid=d3ad4318127f1dde6f3426a81130c826&utm_source=bing&utm_medium=cpc&utm_campaign=PUSH - UK - Smart Shopping - All Products&utm_term=4587299957884345&utm_content=Ad group #1
notice they availble in all sorts of materials
You can get even bigger ones made from plastic and fit felt pads to the bottom, that should do it. Different solution, but would you consider some form of rug?
What about making your own castors? Make them out of wood and to a size that spreads the weight better.
We use those plastic cup ones with felt on the bottom that the castor feet sit in, they've not marked our oak flooring at all.
Now you've had some sensible answers I'm more intrigued by all this "filming" that goes on in your living room ;)
Basically, I'm an independent filmmaker; I make obscure art-house films; you guys probably aren't sophisticated enough to have seen any of them. We use the floor a lot which is why it's important to get the bumps out.
I thought I was stuck but the old iron/steam trick seems to have worked! This means production of "ArchwayAss 6" can go ahead as planned.
...you guys probably aren't sophisticated enough to have seen any of them.
Ah, so you come here for people like us luddites with common sense which so many of the "sophisticated" people, like yourself, sadly lack in spades to fix the problem?
Put it this way; in my movies the man who comes to fix the washing machine rarely ends up getting round to it. So I have to come here.
If only they'd bought the extended warranty on the washing machine ;
suppose I'm intrigued what kind of feet/gross weight the sofa had to be able to create that damage, even on pine.
have old carpet offcuts under the feet of mine
Wait, did you sand your floorboards using a hand sander?
