- 14 Jul 2005
- Birmingham
Im going to be installing a ledger beam on a brick wall to hang additional loft joists off for improving my loft storage. Hoping to use 6x2 ledger beam and same size joists. It all needs measuring up still.
Ledger beam will be fixed to brick and I want to use chemical anchors with threaded bolts, nuts and large washers.
What size and length bolts do I need, how much of the bolt needs to be within the brick?
The joist will be 2" thick (actual dimension I think is around 45mm), and I'll need some thread protruding for the washer and nut, so that is at least say 65mm sticking out from the wall to be safe. How much thread in the wall and what diameter bolts do you think?
a lot of the anchor bolt threaded rods look to have a section where there is no thread on. Not sure why, but if this section happens to land where the surface of the material is, then obviously it won't be able to be tightened properly.
Thanks
Thanks
