Talk to me about Room Treatment
29 Jul 2010
Lincs
Just looking for some advice about DIY accoustic panels.
I've got a music/cinema room that I've built from one half of a double garage. So it's quite small at 3.8m x 3.3m x 2.3m, though I did use heavier materials like blue board, thick selatex and solid core doors to help the room not be too energetic, which seems to have worked as I don't seem to have any problem with the upper frequencies, just some of the ubiquitous bass ones!
Just to say, I'm not trying to make this into a recording studio and I don't have (or really understand yet) all the science about standing waves, room nodes etc, I've just been doing trial and error with various things and see what changes.
The main issue I had was a boom (or resonance/drone/thud - not sure how to describe it) in certain bass frequencies that I found distracting while listening to music. I've done all the things I can to isolate/stiffen the speakers and equipment from vibrations (and tbh, the bass is fantastically controlled) so I came to realise it's a room generated issue.
I've bought some cheapish "accoustic" foam bass traps for the rear wall corners behind the speakers, and tbh, they've done a good job - not only taming a lot of the bass boom, but made the mids/highs clearer and warmer*
The main issue I have now is the back wall reinforcement. The sofa is a little off the wall at 30cm, but the amount of bass reinforcement you get is significant. The difference between where the sofa is now and another say 60-70cm forward is very significant and noticeably improves the SQ. Unforunately, that just brings the sofa too close to the TV to be comfortable, so I prefer it where it is.
So I'm looking to make 4 panels to go across the back wall (and prob 2 more for the side wall 1st reflection) and wondered if there's any pointers and does or don'ts.
Size wise, I'm thinking something like 500 x 1200mm for 3 and 300 x 1200mm for 1 (as it goes on a narrow door on the back wall). Wood frame, suitable fabric cover and either rockwool or accoustic foam. But what thickness should I be aiming for. Common ones seem to be 2" or 4", so was thinking maybe 3" as a compromise as the back wall could probably take 4" ones, but it's going to be pretty bulky. Thinking about 2" ones for the side walls, again more for the aesthetics - even though it's a dedicated listening room, it's still got to have some form, not pure function! :p
I guess one concern I have is not over dampening the room, but doing a few calculators and they do seem to advise about 6 panels for a room of my size.
* I have found though, that when I put these floor to ceiling I find the bass stops dead and loses too much reverb (?) so the sweet spot seems to be only covering half the way up.
Room nodes are directly related to the size of your room. Controlling those nodes is virtually impossible in a small room using passive traps.
The key options that I’m aware of are:
- buying speakers that have a frequency response that doesn’t extend to the same level as the room node (ie some small monitors)
- bass control knob on some amps. I’m not a fan as these tend to be very broad brush about how they apply changes to frequencies and room nodes tend to be at quite specific frequencies, which are correlated with the size of the room
- DSP. This to me is the Holy Grail for a typical UK house. Assuming you’re working with digital files, there’s a host of options now for creating a filter that reduces/eliminates very specific frequencies. There are plenty of COTS solutions, eg DIRAC, but it can also be fairly easily done with a Mic, laptop and a frequency sweep if you’re happy to keep it simple
Thanks Mr Sukebe
Is it still not worth the passive traps for the reflection off the back wall?
Not looking to replace my speakers! :)
Yea, no EQ on my amp anyway, it's a Rega Elicit-R
I'm very happy to keep it simple!
I am working with digital files, using a Naim ND5 XS2 for the streamer. I don't really have a clue how to implement any DSP on my setup, could you explain in simple terms? I mean I understand that I need to find what frequencies are causing issues* but I would have no idea how to create a filter.
* I assume this is relevant - I was messing about on YT the other day and found a "speaker test" video and at one section it played a tone starting for 20K Hz down to 20 Hz iirc and when it started to get to the lower frequencies, there were significant increases in volume at ~125 Hz and again ~87 Hz (very roughly) and I assumed this was an indication of the problematic frequencies?
Thanks Mr Sukebe
Basically output test tones to each speaker, and sub, using REW and UMIK1
Use REW EQ calculation to flatten peaks
Insert those filters into a streamer (wiim pro plus)
Thanks Hornet
I think my babel fish will be able to translate that ;)
Seems my streamer doesn't accept any EQ filters, would your suggestion require replacing my streamer with the example Wiim or is the Wiim an additionional piece of kit in the network? As it would seem a bit of a downgrade from what I have.
Just to confirm, these are replacement options to my current streamer rather than adding an extra piece of kit?
Either buy new streamer with peq
New integrated amp with room EQ ie lyndorf
Or avr with room EQ
Or AV pre amp with room EQ
Antimode on its own will EQ sub but not speakers
Another option is minidsp or antimode expensive mode use that as pre amp and room EQ.
Ref bass traps, I have a pair of GIK tri traps behind my speakers. They’re good for reducing some of the reflected sound, but in real world terms, help to clean up the low end and improve definition. I really don’t think that they made much difference to the room node that I have in our lounge.
For ref, our primary is +12db at 38hz, though it’s in a fairly slim band. We have a secondary of +6db at 76hz.
Ref your Naim, sorry, I’m not familiar with its software.
Whilst the Naim streamer doesn’t have the capability, maybe the server/hosting software that you use does? If not, will the Naim work with another piece of server software that supports EQ?
Dirac ART (active room treatment) apparently releases soon on Denon x3800h. I've had a chat with a betatester and he said that with just 4 small subs it obliterates most professionally treated rooms. In short it works similarly to active noise cancelling in headphones - speakers emit waves that cancel room modes.
The downside is the cost, full package is around 750usd on promotion - thats over and above cost of the avr.
Sod that. Plus it's locked to that AVR.
Yea, that's what I found too with the foam ones I put behind the speakers.
I knew the DIY panels wouldn't fix room nodes, I was just thinking of reducing the reflections to do more of the same as the tri-traps, as atm its just all bare walls and quite a small room.
Is your Naim Roon supported? Roon has PEQ features built in
It is Roon compatible, that could be a good option to explore, thanks!
I use EQ with Roon. Unfortunately Roon is far from cheap, but if you're OK with that, it really is a great piece of software.
yeah to buy / rent roon is not cheap, samsung just bought them out so no idea future of that.
Better to just buy new streamer with EQ features, or a new integrated
That's if you feel it's worth it.
Dirac ART (active room treatment) apparently releases soon on Denonx3800h. I've had a chat with a betatester and he said that with just 4 small subs it obliterates most professionally treated rooms. In short it works similarly to active noise cancelling in headphones - speakers emit waves that cancel room modes.
ART looks good but no single solution is the golden bullet, you need to start with good fundamentals, and paired back to its basics thats room dimensions, speaker selection and some basic treatment, imho EQ should be the last option to add some polish.
I have Dirac live with multisub and its a good product, if Arcam release ART support i will probably upgrade as i have back wall bass buildup issues.
Of course its not a single bullet but I admire Dirac for trying to deliver high end experience to the "masses". Most people have less then perfect rooms and Dirac certainly increases WAF as you dont need so much physical treatment. I would go as much as that with good directionality speaker(WG or coax) and Dirac all you really need is some thick carpet, curtains and some rugs and you are close to studio quality. But multiple subs is a must IMHO, you cannot achieve well behaving bass in most rooms with just 1 - it will always be boomy one way or the other.
I don’t believe that it’s quite that simple.
Naim makes good gear and has a quite distinct presentation style. Changing to say an integrated would throw those benefits away.
New streamer like eversolo A6/A8 will allow you to use PEQ, but will only be for that device.
A new integrated / pre amp with room perfect or similar will allow it for all sources.
Or could use a pass through EQ device between source and pre or pre and power.
Or use roon EQ
Wiim Pro, digital out into a quality DAC
I'm in similar situation, regular hifi, no PEQ, with a subwoofer with antimode, but no speaker EQ, but on the source EQ will effect speakers and sub which isn't ideal, as in effect two cascading EQ's, want PEQ for left, right and subwoofer pre out
