- 30 Sep 2005
ill be there soon
Ocuk ocuk
ill be there soon
Should be in post 1@glenimp617
hi mate, do you know what all the settings are set to for race day ?
do we know if we have things like Tyre Wear, damage, fuel, engine temps, brake and tyre temps etc etc ?
I'm not sure there's a setting for those, I'll need to check. I had a warning in practice though when I closed the vents too much.Laps - 12
Drivers Aids - Authentic
Damage - Off
Tyre Wear - Off
Fuel - Authentic
says nothing about engine/oil temps..
@ShiWarrior is asking as he closed the air vents.. and had high oil temps.. and wondered if that was going to affect anything in the race..
but as damage is off.. then shirley your engine is safe?
Laps - 12
Damage - Off
Tyre Wear - Off
Fuel - Authentic
That was my secret weapon !!!
Yeah i put it to 0% and did over 12 laps with no problems
temps were extremely high
Steamlink should require less processing as it uses foveated rendering (your peripheral vision is rendered at a lower resolution). This is good for those who need extra fps, but you can't turn it off.
Rumours are Steam Link is in fact a test of wireless for the forthcoming Deckard headset which will almost certainly use eye-tracking
that would be a downgrade ?
May i request a circuit for next year please ?
before anyone else suggests it, id like Monza added on for next year![]()
