At the moment I have an i9 10940X LGA2066 on a X299 motherboard, I got this as it has 48 PCIe lanes
Ive been looking at a 7950X3D but today I discovered it only has 28 PCIe lanes
At the moment I have a RTX 4090 installed, this uses 16 lanes
I also have a creative ZXR sound card installed on a PCie slot, needed because of the 600ohm amp for my headphones, and a Wifi 6 wireless AX PCIe adaptor so it connects to my AX router, this takes up 8 and 8 lanes
I then have 4 10tb 7200rpm drives for storage and 3 M.2s/SSD's for games and apps
Not to mention 8 fully used USBs from the motherboard (peripherals)
So if I purchase the 7950X3D will I face issues with my set up, like will I have to sacrifice some of the PCIe components ect to get it working fully? because of the lack of lanes on the 79503DX
Eventually I have plans to remove the 4x10TB drives in a synology or Qnap and hook it up to my router for network storage
Get rid of my ZXR sound card and replace with a desktop headphone amp
Get rid of the PCIe AX wifi adaptor and use a ethernet cable
But until then I'm thinking a direct CPU to the AM5 chipset 79503DX and DDR5 ram along with a new motherboard may not work with my current set up?
