The game support 16k resolution and up to 1000 Hz displays. By default it start full screen, but you can switch to windowed mode by Alt + Enter.
By default it run with high-dpi support, but you able to disable it by "-ldpi" cmd line arg.
For custom window resolution you can use "-width 1280 -height 720"
To disable vsync "-novsync"
To skip all legal ♥♥♥♥ at start "-nolegal"![]()
£19.52 on kinguin with 4.25% cashback.
My question is, does it support ultrawide...
it does support ultrawide - i can confirm - im running 3440x1440 out the box without changing any settings.£19.52 on kinguin with 4.25% cashback.
Edit*
Found this:
Will buy on Steam for £22, see if it all works, if it does then refund and buy from Kinguin![]()
Show in 3440x1440 for me - but its centred for the main menu and on the right its option to goto the next game. its 3440x1440 not stretched for both remastered and original in game.How do the menus show?
Menus are old school and centred yeah, clearly designed to be used with a controller and the game controls can be changed to modern so mouse look works etc.
From the quick test I did just now, the camera does spaz out and get stuck in narrow areas, the mouse look movement isn't as precise as you might want it to be, and jumping off ledges, like in TII in Lara's home doing the jumping course in the garden, the jump reaction time is quite pants so you end up missing the jumps and have to start again. I can see that being rather annoying but will play it properly later.
My 4090 just about managed to maintain high fps in this though, phew was a little worried![]()
Your 4090 is struggling on this?Menus are old school and centred yeah, clearly designed to be used with a controller and the game controls can be changed to modern so mouse look works etc.
