It sounds like you're switching though, not routing.
So their own specs are wrong?No, the NAS is plugged into the SFP+ port designated as the WAN port and its runn8ng the DHCP server and doing the DNS lookups. It’s pushing several GbE across 4 of the remaining 9 ports.
Not me that's the official test results. You should send them yours, they're massively underselling it.NAS is on 192.168.0.x /24 and the clients are on 192.168.1.x /24, all are using the CRS as the DNS Server, DHCP server and gateway. It’s routing. The firewall is running only the basic rules but the firewall is running. I’m not doing any QoS.
4 clients of 1GbE connection each, so not 2.5GbE but the NAS is feeding them backup data and saturating all the connections. So unless something is very off, it’s routing 8 times faster than @robj20 reckons it should be able to.
And NAT, and maintain a route table, and a firewall. Which is possibly why the published figures differ so much to just having a NAS hooked up to the WAN port.Possibly irrelevant for an EE 1.8Gbps connection though since it would have to do PPPoE on top.
Is there some technical reason why EE is offering 1.6GB packages when the rest using openreach does not, or are they just the only one to bother with that speed. What is the actual max upload/download that domestic Openreach infrastructure can handle ?
What’s the reason for having the NAS in a separate subnet?
This is a good read:Is there some technical reason why EE is offering 1.6GB packages when the rest using openreach does not, or are they just the only one to bother with that speed. What is the actual max upload/download that domestic Openreach infrastructure can handle ?
Personally I see even 1Gb as overkill for even a gaming household, but at a starting price of £25 a sync 900/900, it's a no brainer really. And through all these years even the slower speeds were more than enough for the same usage patterns with the same connected devices and users. At up to Gigabit speeds, things download so fast that any impact to other users is never noticed anyway.
Anything faster doubly doesn't make sense when you factor in the cost of routers and switches with multiple 2.5Gbit ports either.
