- 4 Jul 2009
- United Kingdom
Controller support is the bane of my group's co-op games. One is using the deck all the time, so if something has iffy controls then it's off the table. You can play anything if this is the only barrier though. Just depends how good the community configs are, or how much time you're willing to put into making your own.Absolutely, usually it's 3rd party launchers or older game without decent controller support that fail. Everything else will usually play at least to some extent!
