I built my current PC nigh on 10yrs ago - with the addition of an NVidia 1070 7yrs ago - and it's finally starting to creek with modern titles. So time to build a new system aimed at running modern titles at 1440p for many years to come, with headroom to upgrade the CPU to say add 30-50% more performance if/when required.
Main requirements are:-
Total is approx £1700-1800 - eek!
Main questions are:-
Uber thanks in advance.
- Quiet running with cooling controlled by software fan curves to ramp up fans when need.
- At least three M2 slots. One for the OS. One 2tb one for games. And I'll bring over an old third one from my current system for misc data storage - A 5yr old Intel 660p Series 2TB M.2.
- Not overly fussed about overclocking, unless it's a simple increase of a multiplier or something. Reliability is important to me.
Component | Description | Cost | Info |
Case | Lian Li Lancool 216 Mid-tower RGB PC case | 110 | |
CPU Cooler | Noctua NH-D15 Chromax Pure Black | 110 | Basically same as I have now (a D14) |
PSU | MSI MPG A850G UK PSU 850W | 130 | Enough power I assume? |
MB | Asus TUF Gaming Z790-Plus WIFI (LGA 1700) DDR5 | 210 | Better alternative? Ideally want 3 or more nVME, take intel 14th gen proc? Don't need wifi. |
CPU | Intel Core i5-12600K Socket LGA1700 | 167 | Better alternative? Integrated GPU nice. Be able to later significantly improve speed with another CPU? |
GPU | Asus Dual 4070 OC | 550 | Seems a good match for 1440p |
Memory | Corsair Vengeance 32GB (2X16GB) DDR5 PC5-41600C40 5200MHz Dual Channel Kit | 95 | Better alternative? Would get RGB but will be covered by DS15 cooler? |
M.2 (C drive) | Samsung 990 Evo 1TB M.2 2280 PCI-e 4.0 / 5.0 Hybrid | 110 | Uses just 2 PCI channels |
M.2 (D drive) | Samsung 990 Evo 2TB M.2 2280 PCI-e 4.0 / 5.0 Hybrid | 190 | Uses just 2 PCI channels |
OS | Microsoft Windows 11 Home 64-Bit DVD | 110 | Windows 11... Blah! |
- Are there better alternatives for the MB, CPU and/or PSU etc?
- I've gone with an ASUS MB, assuming their current bad press is a blip.
- Assume the Asus MB Aura RGB controller socket will take/accept the Lian Li's ARGB wire (to control the front fan colours etc)?
