So currently running a rig with:
- Ryzen 5600 with Arctic Liquid Freezer II 240
- Gigabyte AMD B550M AORUS PRO-P M-ATX board
- RTX4090
- HX850 PSU
The 5600 was always a stop gap upgrade meant to be replaced.
In May, I'll get a remote working stipend of ~£450 and I'm planning to use that to upgrade some bits.
I first looked at a proper upgrade - 7950X3D, board, DDR5, PSU and case, but an ideal build was coming to close to £2,000.
Instead I'm just thinking about dropping a 5950X into my rig.
I know 5800X3D is the better gaming GPU, but I have some work and productivity use cases where I prefer the 5950X.
Just wondering about thoughts on the upgrade.
Most think this specific B550 board should be ok.
P.S. Yes I know my PSU might be cutting it a bit fine. Will think about updating that, but most sites suggest I'll be ok.
- RTX4090
- HX850 PSU
