Virtual Desktop Vs Steam Link
20 Oct 2002
Oxfordshire / Bucks
Tried Steam link tonight on only one game (Automobilista 2)
The difference to me :
VD) runs no problems, but i think the game tears, but graphics are sharp
SL) Tearing effect has gone, but less sharp
Game performance graphics are set to Ultra (I've tried High and tried Ultra tonight on SL to see if the sharpness would improve)
any idea if i could improve things?
I've only had a Quest 3 about 10 days. I've tried it in 2x PC's (3090 and 4090) and not seen any tearing at all. I couldn't get it as sharp as say a Reverb G2, but could get it looking very playable without much latency.
I'd try running VD set to Godlike v264+ and 400Mbps, and lower the game graphic MSAA settings down a touch. Godlike encodes 3120x3120 rather than the 2600x2600 which ultra encodes.
What SteamVR resolution are you running?
You need to enable VD performance overlay and check things are ok....then run fpsvr and check gpu/cpu.
Set shadows and reflections to off or as low as they will go. MSAA is a big factor as mentioned above but will introduce shimmering if you haven't the gpu for it.
If you really want to push the absolute max graphics on the 3090, you are going to have to get stuck into openxr toolkit with opencomposite. That will give you +10% boost straight away.
ok , just tried WIRED for comparison
that's defiantly the sharpest tool in the box so far, but sadly i get no sound in the headset (tried changing it in windows settings to each of them, nothing) so i would have to use the soundcard which is doable i suppose
i will try VD again (ill try wired first) and take shadows off and see if there's any difference
I was going to say if you're using it for sim racing a wired connection and upping the encode bitrate in the oculus tool to 940 makes it flawless if you have the power to run it
You have to choose oculus audio device I think in the sound output settings (click on the sound icon in the bottom right of taskbar).
There was not that option in the windows, settings, sound
I tried about 5 different sound sources none of them worked unfortunately
Wireless says virtual device
But I haven't got that same option via wired iirc, I'd have to check though
Hey I know this is a bit late but If I am using Virtual desktop can I still run fpsVR at the same time even though I am using the VDXR runtime and not SteamVR to play Automobilista2 on the Quest3
no run oculus debug tool and run the visible performance overlay HUD in that
Ps and join us in the league discord
I could never get on with Steam Link. It was always jittery.
I used to use Meta Link but now have switched for some games to Virtual Desktop VDXR with Open Composite which gives a big improvement in performance.
Use H264+ on Virtual Desktop, and with a good router you can use 400 or 500mb/s (Quest 3) which approaches wired cable clarity.
I can now run Skyrim VR with over 400 mods on VD 'Godlike' on Quest Pro at 80fps with no reprojection. (I do have a 4090 though).
Oddly, for me Steam Link was the only one of the free options that gave me a smooth experience in Elite Dangerous. Meta Link (even over wired) was really choppy when turning.
It's entirely possible that VD might be even better, but I have a very low tolerance for tinkering with settings. Having found something that works well, I'm very reluctant to pay for something that will probably need more tweaking to get it working right.
