hope this makes more sense and able to follow
Where has the 5.05% easy access rate come from?
Top savings accounts
Find the top interest rate savings accounts & maximise your returns with Martin Lewis' guide. Includes the top easy-access and fixed-rate accounts to help you find the most profitable home for your cash – and keep it safe.www.moneysavingexpert.com
i could use a higher interest rate to make my numbers look even better if you really wanted![]()
it's an average rate because the money was never in the account right from day 1If you can get 5% easy access why are you drip feeding regular savers at a lower 3.5% average rate?
While regular savings accounts can pay higher rates of interest, the problem with them is that it takes time to build up the amount of money you have in there. Yet if you have a lump sum of cash, and you want to maximise its earnings, you can still take advantage.
- Put the lump sum in the top-paying easy-access account.
You'll then start earning interest on the full sum straightaway (see Top savings accounts).
- Then, pay in to the regular saver from the easy-access account each month.
The key is to put as much as you can (up to the monthly limit) into the regular savings account to max the interest.
This technique is called 'drip-feeding', as you're slowly moving your cash across, month by month. This means every penny you want to save is earning the most it can at any moment. Here's how it should work in practice...
Let's say you have £3,000 in savings. If you start by putting this in the top easy-access account with unlimited withdrawals and moving £250 across to a top regular saver in the first month, you'll have £2,750 earning the easy-access rate (for example, 4.1%), and £250 earning the higher regular saver rate (for example, 6%).
This way, you can keep getting interest on the lump sum while getting a higher rate on the money you pay in to the regular saver. After 12 monthly payments, the full amount will be in the regular saver. You can then move the whole lot to the top payer at the time and start the process again with a new regular saver (provided they're still around).
To get the maximum gain, put as much in as possible in the early months, but always ensure you've enough left to keep up the minimum payments for the account's lifespan. Then you've got as much interest as possible, while meeting the account's terms and conditions.
Sorry mate still confused. If you can get 5% easy access why are you drip feeding regular savers at a lower 3.5% average rate?
no, i've assumed the full 12k sitting in an easy access whilst it's being drip-fed into regular saversAh ok I think I see what you've done, to get around the comparison of having the full 12k upfront you've assumed half sitting in easy access as it's drip fed across to the reg savers.
yours = £600 interest
mine = (£12k x 2.5%) + (£12k x 3.5%) = £300+£420 = £720
no, i'd have £12,720 vs your £12,600reg savers you will move that full £12,420
doesn't really matter as your bonds would have matured at the same time as my regular savers, so we'd both have the same dilemma and hence cancelled out.So bit of maths required to see what is better. I think it will depend what your ISA rate is.
yes i remember that lol. hard to convince people that bigger usually is betterI had a similar discussion in this very thread months ago.
the only thing different is that i'd be £120 wealthier but had to spend an extra 30 mins or so setting up my regular savers at the start
facepalmaverage of 3.5%
apply what you said to the regular saver accountsSame thing as saying half the money at the full rate. Or half the time at the full rate.
pretty sure 7% is higher than 5%In a steady state scenario the higher average rate would give higher returns.
when you get a chance you can prove me rightLike I said, can't demonstrate it as don't have access to spreadsheet or pc right now.
Yes, at half the rate which is where you got 2.5% from. Same thing as saying half the money at the full rate. Or half the time at the full rate.
I still think the higher rate would give the higher returns but I can't sit at a pc with spreadsheet to demonstrate.
But think in a steady state situation - let's say every month for many years you'd been saving £1k into reg savers at an average of 3.5% and then at year end paying that into your ISA, Vs every month saving £1k into bonds at 5% and then every month as your bond from 1 year ago matures, paying that into your ISA.
when you get a chance you can prove me right![]()
yes please doHappy to be wrong, will see in a week when I'm back off holiday.
Your making the mistake of halving the regular savers rate again, the rate is the rate.
The interest gained is roughly half of the headline amount x the maximum capital invested, it is in fact 54%, but thats because in effect only 54% of the capital is invested in the regular saver.
Take 54% of the real rate x the maximum amount, take 46% of the alternative product the rest of the money will be in based on the whole amount and thats your interest.
Your hung up on halving the regular saver amount because those who get it correct often correct people who think they will gain interest based on the whole capital amount at the end which is wrong, but the interest rate IS the interest rate.
Around 79% but the tracker we're on is for 90% LTV. The one at 80% is actually more expensive but with less of a fee & even at 75%, it's only 0.1% cheaper that what we're on now.What's your LTV?
You say that but when we got the ball rolling 6 months, the rate we were quoted then was 6.12%!That is really high. Isn't that like the peak of what fixes hit?
It looks like it's coming down slower than I thought/hoped
Its not semantics at all.Jesus Christ mkw it's just semantics.
Halving the headline rate is just a quick and easy way to do the maths on a reg saver account.
| Month | Invest | Bond @5% | Regular @7% |
1 | 100 | 0.4 | 0.6 |
2 | 100 | 0.8 | 1.2 |
3 | 100 | 1.3 | 1.8 |
4 | 100 | 1.7 | 2.3 |
5 | 100 | 2.1 | 2.9 |
6 | 100 | 2.5 | 3.5 |
7 | 100 | 2.9 | 4.1 |
8 | 100 | 3.3 | 4.7 |
9 | 100 | 3.8 | 5.3 |
10 | 100 | 4.2 | 5.8 |
11 | 100 | 4.6 | 6.4 |
12 | 100 | 5.0 | 7.0 |
| Year interest | . | 32.5 | 45.5 |
| Invest | Bond @ 5% | Regular at 7% | Instant at 4% |
1200 | 60 | 45.36 | 22.08 |
