Having loads of fun (not) mounting the telly and soundbar this weekend. As usual it takes approximately three threads on here, a last minute dash to Wickes (new drill bit) and the whole weekend
The telly mount plate is a vertical bar type thing, with four 10x80mm screws/plugs provided. All kosher as far as weight allowance goes, but as usual drilling through our Victorian brick walls was more problematic than I hoped. Fortunately the top two holes are nice and neat, no issues there. But for the bottom two I hit some sort of concrete and the drill went walkabout a bit. So the plugs are pretty loose particularly around the “entrance”. I wrapped a couple wet-n-fix things around them and they don’t actually move much (I think it’s tighter further in, and at least I have 80mm to play with). But just wondering what I should pack in the entrance holes (ooer). Match sticks? No more nails?
Am I stupid for not being too worried? My GCSE physics tells me the top screws will be taking most of the weight and “pulling” on the screws whereas these bottom ones will be pushing against the wall right? I also put another 10mm plug in a centre hole the mount had so I’ll have an extra screw there.
Total load is like 18kg all in.
*checks insurance policy*
It has a drill icon and then 0-20 torque speed to choose from.
