looks good mate. Another nice clean build
Also I managed to fit the aio in the front of my phantek evolv x.
I ordered the 360mm & the 420mm as am going fit one of them into my Evolv X case
But I have no idea if it going be better to use the 420mm in the front (intake) or to use the 360mm in the roof (exhaust), it going be used to cool a 14900k
"fo-fan" (?). The non RGB has zero RGB plugs and no lighting. The outer fan effect on the pump housing, the look, is just black. The VRM fan is internal to the fan effect look. On my A-RGB version it is coloured white, I suppose so that the RGB lights emit light through it.
@humbug To be frank, I can't say that, for me, getting the A-RGB version was worth it. From an aesthetic point of view. I can't see anything at all in terms of RGB for the fans, the radiator being in the top of the case, which in turn is placed on the floor. The radiator is set above the fans so all you see from the outside is the black of that.
The small circular block fan is.....................kinda mediocre, but ok I suppose.
The cheap set of RGB lights x4 strips that I bought from Amazon, plug into the motherboard, have been far more effective.
Overall, I would now have bought the Non A-RGB type for the 420mm at £71 than the the RGB type at £83.
I genuinely don't see the appeal of RGB.
