New version of DirectX12 released with updated Agility SDK - brings new features for Devs
6 Feb 2019
Microsoft has released a new developer SDK for DX12 and it brings new features for developers to DX12 games.
They include:
* Shader Model 6.8 - new features to Shader Model 6.8 are Work Graphics Management, Vertex Instance Location, Wave Size Ranges and Comparison Sampling
* GPU Upload Heap
Link to technical documentation below, but a quick summary of what the most important new features do:
* Work Graphics Management: Currently CPU's schedule work for GPU's but do this inefficiently, this features allows the GPU to schedule it's own work or to tell the CPU how to schedule the GPU's work - this feature is designed to reduce latency in the graphics pipeline.
* Comparison sampling: This feature makes it easier for developers to manage pre shader compilation across PC and Consoles, instead of having to do shader compilation differently between systems.
* GPU Upload Heap: This feature allows the CPU to address the entire GPU VRAM frame buffer, instead of only addressing 256mb chunks, this allows for faster data transfer between CPU and GPU. This feature requires Resizeable Bar to be enabled and supported by the PC.
In summary most of the new features are designed to reduce pipeline latency, allow GPUs to better schedule their own work and to allow for faster transfer of data between the CPU and GPU. Microsoft says it has implemented these changes because Epic Games has requested it. I would assume these are changes Epic Games hopes will alleviate Shader Compilation and other stutters that are common in Unreal Engine 5 games.
For the gamer's PC to support all the new features, the following conditions need to be met:
* The system must support resizeable bar
* Must have a RTX3000 or newer Nvidia GPU or RX7000 or newer AMD GPU (Intel GPU currently not supported)
* Must be using the latest GPU driver from Nvidia and AMD that was recently released (may be in beta)
* Must be using the latest build of Windows 11 (currently in beta)
Can read more technical documentation here: https://devblogs.microsoft.com/directx/directx12agility/
Will these be driver level changes do you think or will they need to be patched into games? I'm thinking about that cyberpunk video that went round about a month ago...
Edit. GPU upload heap. Does this mean rebar will finally work properly on Nvidia cards?
New features for developers. Sounds great, but need a bit more coverage to see it in action and what games can implement that.
Ed-
NVIDIA’s latest Game Ready Drivers and NVIDIA Studio Drivers (version 531.41) offer support for both GPU Upload Heaps on Ampere and newer GPUs and Non-normalized Sampling on all GPUs.
Just not sure about windows build.
Starting to wonder if I should stop recommending rdna 2 for gaming PCs if this cut-off is going to continue.
They include:
* GPU Upload Heap
First thing that i thought when reading this was about shader model support.
Given that GPU-Z currently states shader model 6.7, for example https://www.techpowerup.com/gpu-specs/sapphire-pulse-rx-7800-xt.b11402
Its obviously just because that is the latest shader model by version number, architecturally these GPU's support 6.8.
